Having clutch adjustment issues on my 28 JD. Tried to use the manual I have but my tranny is a 25 so not the same procedure. Adjusted so that clutch disingages the tranny can't kick start cuz it just slips. Tightne it up so plates do not slip during kick start and tranny will not disengage and the gears grind during shifting. Brand new plates. Any sugestions?
Clutch adjustment
The experts would be at Waseon for the weekend. I'm sure you'l get your info by Monday .Originally posted by wyatt emp View PostHaving clutch adjustment issues on my 28 JD. Tried to use the manual I have but my tranny is a 25 so not the same procedure. Adjusted so that clutch disingages the tranny can't kick start cuz it just slips. Tightne it up so plates do not slip during kick start and tranny will not disengage and the gears grind during shifting. Brand new plates. Any sugestions?
There is a large thrust washer that slips over the mainshaft just before the clutch is installed onto the mainshaft. Is it the correct thickness? If it is too thick, clutch adjustment is impossible. They came in various thicknesses. One should be selected so that there is about 0.005" gap between the thrust washer and the back side of the clutch hub bearing race. It's easiest to measure with the gearbox and clutch out of the frame, but it can also be done in place.
Another thing to consider is I the clutch is assembled correctly.
Mark MasaMark Masa
www.linkcycles.com
