Harley JD Fork Trade
  • Harley JD Fork Trade
    I have two Harley J model rear legs that I'm looking to trade.
    The legs that I have are correct for 1922 and 1923 74" models as well as 1924 61" and 74" models.
    One is in very good condition and the other will need a little straightening. No kinks, but it's a little wonky.
    I can email or post pictures.
    I'm looking to trade one for a 1928-1929 rear leg and the other for a 1925-1927 rear leg in similar condition.
    I may also consider trading one for a 1919-1921 /1923-23 61" style rear leg.
    They are not for sale! Trade only!
    I also have other J/JD parts to trade in the event that you have the fork that I need, but don't need one of mine.
    Mark Masa
    Mark Masa
    www.linkcycles.com
    The 1922-23 74" / 1924 61" and 74" rear fork leg and the 1925-1927 rear fork legs are very similar.
    Here's a picture that will help tell the difference.
    The measurement is from the underside of the bottom crown plate to the center-line of the stud / hole.
    The 1928/29 leg is the same as the 1925-27 leg except that it has a stamped steel brake anchor bracket wrapped around and brazed to the bottom of the left leg.
    Mark Masa
    Mark Masa
    www.linkcycles.com
      Just floating this to the top again. I still have the forks to trade.
      Mark Masa
      Mark Masa
      www.linkcycles.com
