1928 HD Build
  • wyatt emp
    • Nov 2010
    • 163
    1928 HD Build
    There have been several requests so here are some photos of my progress on my 1928 build. Building from parts as a Rat Rod as I am able to aquire them, which I have beeen told is imposible. 6 months in the works so far. Hope to have it on the road by spring. Started with the frame, tranny, gas tanks, wheels, and lower end motor. It also came with the original registration card from 1928, which is a "very cool" factor. The only parts I am missing at this point are the chain guards so it CAN be done. Front cylinder is done and rear will be mounted this week. Waiting on generator gears and I wil have all the parts I need and will be mounting the motor.SS850591.jpg100_0069.jpg100_0070.jpg100_0071.jpg
  • DanM
    • May 2005
    • 465
    >Lookin good!
    Dan Margolien
    Www.yankeechapter.org
    Pocketvalve@gmail.com
    • wyatt emp
      • Nov 2010
      • 163
      Thanks. I now know the meaning of "Labor of love"..........
      • wyatt emp
        • Nov 2010
        • 163
        • wyatt emp
          • Nov 2010
          • 163
          Mounted the motor last night. When timming the gears I was able to get all the marks to line up perfectly except the breather gear. It is off ab100_0123.jpg100_0124.jpgout half a tooth and could not get it any bettter. Hope that dosn't cause me any issues.... Tanks will be back Monday.
          • wyatt emp
            • Nov 2010
            • 163
            Well, got my tanks back. AARRGGG! The guy had them for two months and kept telling me he was alomost done. Got them back in the same condition I gave them to him as he did nothing!!!!! Back to square one.
              • 6018
              A number of years ago I had an Indian Big Chief that had a less than perfect gas tank. I took it to a guy at a radiator shop who was highly recommended. When I first talked to the guy, he sounded like he knew what he was doing, and assured me that he could disassemble it and reassemble the tank with no problem. I think it was 6 months later when I surprised him at the shop (I had been getting avoided). He was drinking a beer that was in a rubber boot so his boss wouldn't see him drinking on the job. I have since taught myself to fix my own gas tanks.
              • 23JDCA 808
                • Jan 2007
                • 688
                Who can put an oil pump in a 1923 Harley JD left tank? I have replacement parts; original pump body is long gone leaving the two holes there. I will guess the tank needs to be taken apart to do this?
                Bill Gilbert in Oregon
                • wyatt emp
                  • Nov 2010
                  • 163
                  Maybe the same guy. I feel your pian brother!!!!!!!!!!!!!
                  • RPjr
                    • Dec 2006
                    • 57
                    Whats wrong with your tanks? If they are not rusted through it should be easy to take apart and fix.
                    • 23JDCA 808
                      • Jan 2007
                      • 688
                      I need the new oil pump soldered into the old hole. I cannot solder.
                      • wyatt emp
                        • Nov 2010
                        • 163
                        100_0201.jpg Modified VL left tank to fit. Still need right side. Rear wheel will be in this week. Start up motor attempt latter this week also. Has spark so?
                        • Tom Lovejoy
                          • Aug 2006
                          • 951
                          Looking good, your alot faster than many of us :-)
                          • wyatt emp
                            • Nov 2010
                            • 163
                            • wyatt emp
                              • Nov 2010
                              • 163
                              Well, got it all togather but got realy frustrated as I could not get it to run. No compression at all. I have rebuilt Model T motors but am new to JD motors. Put it up for sale and sold it, but the guy backed out after giving me a deposit. Turns out to have been carma as I realy did not want to sell it anyway. Went back to it with a fresh attitude and found the exhaust valves were so out of adjustment they were open all the time. This should have been the first place to look, but just didn't the first time. Adjusted the exhaust valves to .008 and the intake to .001. Turned on the key, gave it a couple of kicks and suddenly, PRAP!PRAP! PRAP! PRAP! PRAP!, "IT'S ALIVE, ALIVE!!!!!!". It is VERY loud as I still do not have a muffler and my horses went nutts. After I fine tune the clutch, I will be ready to take her out for a test run. I am quite nervouse about it as with the suicide clutch and all, is very different from a modern bike. I will let you all know how it goes, if I survive!
