Hello,
In disassembling the front damper I found that it has been wrongly put together and that the main "recoil spring guide rod" #298 has been replaced and some other parts missing as well.
Looking in the spare parts catalogue, I tried to figure out how it should go together. You in the know, Did I get it right? please see the attached drawing view.
I am missing #299 "recoil spring washer" I guess that the i.d. of the washer is the same as the o.d. of the guide rod?
the #301 "lock plate screw" B014W, what kind of screw is this?
I need to make a new guide rod. If I understand it right it is important to get the length right since this will set the overall length of the damper once put together. it also looks to have domed upper shape?
Could someone please measure an accessible length of the damper?
I would really appreciate if someone could help me.
Martin
Martin
