Dixie Magneto gear on a 17F
  • partshunt
    • 285
    I am changeing out a scuffy mag driven gear with an NOS gear on an H-D 17F. However, the NOS gear is listed in the parts book as being for Bosch and Berling mags only, identified with three holes thru the face of it, PN 626-18 for 18 and later. The gear I am removeing off the Dixie is a solid style gear shown in the early parts books to 1917. The NOS Bosch gear fits perfectly, so I dont know why it is not shown to fit earlier Dixie mags. I see no problem but am I missing something here?, The taper, key way and timeing mark are the same and located with the same positions. What is going here?...Anybody useing the later gear on a Dixie with success? Thanks, any input would be very much apreciated...Joe
    Joe AMCA# 3435
  • MMasa
    • 1192
    Have you ran the bike with that old gear?
    Mark Masa
    Mark Masa
    www.linkcycles.com
    • partshunt
      • 285
      Hi Mark:- It did run for about 10 minutes on start up some years back but the Dixie base shattered right away. As you know they were made from Pot Metal like material. So, it has a new alum base on it now I got from Barry Reeves who casts them. The 17 has been running with a Bosch running with a good gear on it. I picked up the other NOS Gear long ago and just want to install on this Dixie. Fits good, I see no problem. Just wondering if others have done the same as me, useing a Bosch gear on a Dixie..It may be that the parts listing just omitted Dixie info their parts listings in the gear description, not sure as the description only mentions it is for Berling and Bosch. Normally, if a part come out in later years and fit backwards, the books always use the word "fits" such and such a prev yr also, then you know its an update and can be used those mentioned on earlier years....Joe
      Joe AMCA# 3435
      • Slojo
        Evil Twin Doctor
        • Oct 2007
        • 880
        " The taper, key way and timing mark "
        Joe, it is best to omit using a key on the taper bore gear to tapered magneto shaft. If (when) you have a magneto failure a week point such as gear slippage on shaft can be your best friend.
        joe
        • MMasa
          • 1192
          Joe is right. It drives off of the taper anyway. The key is just there to automatically time it.
          Small world! I just bought a base off of Barry yesterday.
          Mark Masa
          Mark Masa
          www.linkcycles.com
            • Aug 2001
            • 1343
            Are you guys saying you actually run your mag gear without a key in it? Where as I've never ran one 3000 miles at a time, I've never thought of leaving the key out either.
            Louie
            YouTube >>> LouieMCman
            • Slojo
              Evil Twin Doctor
              • Oct 2007
              • 880
              Louie
              Toss the key.
              During cannonball I overheated the insulation on my magneto armature. This results in a softening of the tar like insulation to a liquid state, stir in a little centrifugal force and the tar accumulation fowls the field. Next your armature is churning the clinging substance to a point where something must give. My magneto drive gear slipped putting the motor out of time shutting me down without damage. A key in the system might cause a broken magneto shaft or drive gear, possibly the pinion gear, that is bad.
              joe
              • fillibuster
                red dog
                • Aug 2009
                • 934
                Originally posted by Slojo View Post
                Louie
                Toss the key.
                joe
                I'm glad to know others think this way (tapers). When I first encountered tapered bushings in industrial drive components I was taught that a tapered sheave on a tapered bushing was such a sure fit that one could remove the bolts and expect the sheave to stay on the bushing, and endure all the torque it was sized for.
                One the Indian Chief the gen drive pulley fits a tapered shaft of about 1/2" with woodruff key, but upon losing the key during a clutch fix (in a far-away pasture) I applied red locktite and about as much torque as I thought the threads could take, and I've run without the key since.
                There! a little Indian on your dam harley thread! ....
                • Tommo
                  • Sep 2001
                  • 1320
                  Joe
                  Think about the whole thing in a purely mechanical sense.
                  If the gear is the same diameter with the same number of teeth, that have the same tooth form, what other things will stop you using it?
                  The only other things I can bring to mind is are the tapers the same and is the sideways tooth mesh correct.
                  If all these things check out there is no reason why you can't use the gear but you should check the tooth backlash through a complete revolution of the gear once its all fitted up
                  Also make sure it doesn't foul the inner and outer cases at all.
                  I thought the only difference was the three puller holes in the gear and that these were introduced to stop people damaging the cases trying to pry the gear off.
                  If you were to fit the gear I'd be getting those three puller holes put in because when you need to remove the gear at a later date, no holes wouldn't bear thinking about.
                  Peter Thomson, a.k.a. Tommo
                  A.M.C.A. # 2777
                  • partshunt
                    • 285
                    Tommo, yes from a mechanical point, you are exactly right. I am 100 % sure it will be fine. I was just asking if others are running this gear on their Dixies. It is a 1918 and up gear listed for Bosch and Berling. just dont know why the parts book didnt state it was good for the earlier years when Dixie mags were used like on my 17F. Every physical feature matches just fine. The only physical difference is the hub face for the nut as it is not flush with the gear itself but that doest matter a rats #$%^. This hub is relieved about .030" below the gear where on the old solid gear the hub is flush. The three puller holes are an update for sure and I see your point there. Its gonna go in fine , the teeth are the same and afterall. it is listed for the early Harley gear train anyway. a very nice NOS gear at that. Thanks to all for your reply and sugestions...Joe
                    Joe AMCA# 3435
                    • MMasa
                      • 1192
                      I've always been under the impression that there was in fact a physical difference between a Bosch,Remy 150/250,Berling gear and the Dixie gear and that it had to do with the orientation of the keyway and the timing mark on the gear tooth. Omitting the key and timing manually negates this, but there is clearly a different part number for the Dixie gear. I guess that I should look at a Dixie mag and see if the key location on the armature shaft differs from that on a Bosch.
                      Mark Masa
                      Mark Masa
                      www.linkcycles.com
                      • partshunt
                        • 285
                        Mark, I layed out both gears and the gear keyway and timeing mark both line up perfectly with the teeth in alignment. I also checked the taper and it also is the same. When the gear is installed on the Dixie mag with the mag in the engine boltad down, the gear meshes with the gear train perfectly. The gear diameter is dead on as well since I can adjust my gear backlash fron zero to excessive. I just found a Dixie on Ebay, a dusty ole speciman with a bosch gear on it. I am beginning to believe the so called Bosch gear is a revised gear for Harley in 1918 and the prev solid gear was just simply dropped with the Dixie when they quit useing Dixies by the end of WWI in 1918. Probably, in 1918, if you wanted to replace your mag, they sent you a Bosch and the new gear. Dixie was no longer supplied, just my thinking. The parts books just dont mention the chageover. That Dixie on Ebay looks like it inherited that Bosch gear long ago. Just key in "Dixie" in the Vintage category and it should come up. He wants aprox 800 bucks for it, sez the base is very good...Kinda the way I'm begining to think.....Joe
                        Joe AMCA# 3435
                          • Feb 2003
                          • 5353
                          Very interesting thread Joe. I've got a Dixie mag on the bench right now. I think the gear is just fine but it's nice to know that there is an option if need be.
                          Cory Othen
                          Membership#10953
                          • partshunt
                            • 285
                            Which gear is on your Dixie?
                            Sending pics of the two types of mag gears in question, pre 18 (Dixie) and post 18 (Bosch) Both measure up to fit the application...Joe
                            Joe AMCA# 3435
                            • pravg
                              • Jan 2011
                              • 3
                              Dixie Magneto gear
                              I have used any of the different gears on Dixie, Berling and Bosch Magnetos and have found them fully interchangable. As regards the omission of the key, I use home made plastic keys for quick timing on the one hand and easy chearing off on the other.
                              As regards timing I found that for giving both cylinders exactly the same timing in most cases some correction of the interrupter cam is necessary.
