28--29 Brake Shackle Question
  • Rod K
    • May 2006
    • 179
    The brake shackle for my 1928 J model has offsets on both ends. One side has longer offsets on both ends and the other side has short offsets on both ends. Which side goes toward the brake side cover. Any help appreciated....Rod
    • 2176
    Dear Rod, if it's like the VL then the shortest offset goes at the front towards the brake side cover. Check the forging number to make sure you have the right one.
    • Rod K
      • May 2006
      • 179
      Thanks Steve.. I mounted the shackle as you suggested and it fit up very well. There were no numbers on it at all. It came with the brake set up when I bought it....Rod
