Linkert M51 float bowl location.
  • John Mertens
    • Mar 2010
    • 22
    I have a Linkert M51 on my J.D, my question is what is the correct location of the float bowl . should the inlet line be directley center of the butter fly.and air intake. or elce where. thank you.
    • 8234
    John!
    The M51 used a "side bowl", with a raised boss for a hex cap (on left in attachment) that will not allow the inlet to be placed directly under the carburetor.
    An original gas line would probably find that more convenient, even though the model is not "correct" for a JD.
    • John Mertens
      • Mar 2010
      • 22
      thanks Cotten.would the bowl then be placed just left as it's clears the center.i see no pins to mark the right place to set it. or it dozen't make any differance were it goes. thanks again Cotten. John
        • 8234
        John!
        You will want to rotate the inlet as close to the choke mechanism as possible.
        If the inlet is anywhere close to perpendicular to the body, the float will hang up upon the bowlstem.
        If the gasline will not allow this, then some extra clearance for the float can be achieved by grinding the protruding ledge upon the bowlstem.
        • John Mertens
          • Mar 2010
          • 22
          thank you Cotten. this has been very helpful.John
