Blackened Brass
  • motorpickle
    • Jul 2009
    • 66
    Blackened Brass
    Hey!
    Anybody out there know how to replicate the "blackened brass" finish on parts for WWII Linkert carburetors? Does parkerizing solution do it or is it some other etching acid that is used. Or is it some kind of paint? Any and all information is welcome. Thanks in advance.
  • sirhrmechanic
    Vigilis
    • Dec 2010
    • 1147
    www.brownells.com
    Brass Blackening is made by, I think, Birchwood Casey among other manufacturers.
    You can also check with Dixie Gunworks in Tennessee. They sell brass black.
    Hope this helps,
    Cheers, Sirhr.
    • motorpickle
      • Jul 2009
      • 66
      Thank you so much!! I always tend to ignore the obvious, but I have an account with Brownell's. This cite is truly a blessing for the uninformed(or senile) like me...
        • 8247
        Motorpickle!
        Exactly which pieces do you consider "blackened" brass?
        Most small hardware was cadmium plated, which darkened by nature.
          Here is a factory photo of a WLA carb from 11/24/43.
          Here is a factory photo of a military U carburetor from 4/15/1944.
          • motorpickle
            • Jul 2009
            • 66
            Thanks Cotton and Chris.....
            I should have asked what finish is needed before asking where to get it. I need the correct finish for the bowl plug,float arm pin and cap,bowl valve seat and top cap and throttle arm. From the pics it looks like the plugs and throttle arm are cadmium. Maybe the correct question is "were there any blackened brass parts on WLA carbs?" Sorry for the confusion...but it comes naturally.......
              • 8247
              Motorpickle!
              I suspect that any 'blackened' brass was a result of time and storage.
              On to other finishes, even cad-plated brass parts could have a range of finish, as shown by these pieces found in cosmoline.
