Low Speed Lever, Linkert M16
  • sirhrmechanic
    Vigilis
    • Dec 2010
    • 1147
    Hi:
    Does anyone have a low speed lever for a Linkert M16 1" carb that I can buy, beg, borrow or steal? Ok... I won't steal.
    I need one for a carb rebuild, and I understand that these are really getting hard to find. If I can borrow one, I will make a run of them to help others out!
    Can anyone help me?
    Cheers and thanks!
    Pierce
    • 4788
    Pierce,
    Help me out here. Are you looking for a throttle lever? Or a low speed needle? I'm not following the low speed lever request, although with an M16 its all low speed anyway! If it is the throttle lever you need I'll look in my stuff.
    Robbie
      • 8236
      I believe that Pierce is referring to the one on the
      right in my attachment (except nickel plated up through '41 or so, and cadmium plated thereafter).
      • sirhrmechanic
        Vigilis
        • Dec 2010
        • 1147
        Here is the one I am looking for:
        Seems they are made of Unobtanium! But if there is a need (and I definitely need one), I will see if I can get some made.
        Cheers and thanks for anyone who can help!
        Pierce
          • 4788
          I found one Pierce, If you need it for a pattern I can send it to you.
          PM me,
          Robbie
          • sirhrmechanic
            Vigilis
            • Dec 2010
            • 1147
            PM sent, thanks! Cheers, Pierce aka Sirhr
