45 oil spill
  • brian r
    • Dec 2010
    • 1
    45 oil spill
    roll my 45 around garage leaves a trail of oil ,whats up
  • Mr. Big
    • Feb 2010
    • 130
    I'd be surprised if it didn't!
    47 WL
    51 Ls Sidecar
    03 FLHT
    http://www.gouldingsidecars.com
      • 4788
      Your oil is draining into your engine and filling it to a level that it leaks into the primary cover where it pools. when you hold it upright and roll it around the oil drains out the back of the primary cover leaving a nice little trail. The check balls in the pump may be worn, or not. sometimes it is merely gravity and many of them do it. The best cure?, ride it more often!
      Robbie
