Schebler GX-1 carb
  • cubman
    • Apr 2009
    • 52
    Schebler GX-1 carb
    I' m working on a 1934 B (H-D). Ineed the throttle lever HD part# 1239-26. Can anybody help me or hook me up with one? Thanks Mike
  • Tommo
    • Sep 2001
    • 1320
    Mike
    As 1239-26 does not appear on the throttle lever you want, it would make it easier for those people who might look in their stash for you if you quoted the Schebler number "G2" that is stamped on the throttle lever you need.
    The letter and number is easy to see when viewed from the top and is stamped either side of the slot that pinches up to hold the lever onto the throttle butterfly shaft.
    So a G2 throttle lever is what you need and no I can't help you.
    Peter Thomson, a.k.a. Tommo
    A.M.C.A. # 2777
    • cubman
      • Apr 2009
      • 52
      Thanks Tommo, I was going by the 1934 HD parts book so using the Schebler number will help expand the search. Thanks again. Mike
