UL clearance
  • kg993
    • 263
    UL clearance
    I am boring a badly pitted set of UL cylinders to 3 7/16 std. Can someone tell me the piston to bore clearance. Don't have a book on B.T. Flat Heads.
    Thanks, Kerry Glaze
    Kerry AMCA # 15911
    • 4788
    Kerry,
    That purely depends on what pistons you are using. Factory Harley is .001-.0015. Most aftermarket are in the .003-.004 range. Who made them and are they cast, forged , etc, as it is all different! Max wear allowance is about .006 over that clearance.
    Robbie
    • kg993
      • 263
      They are from V-Twin, cast pistons.
      Kerry AMCA # 15911
