Oil tank emptying while sitting?
  • Knotthed
    • Jul 2008
    • 195
    I need some trouble shooting help here.
    1953 Harley 45 - after sitting for a period of time the oil tank is completly empty!
    What could cause this? There are no obvious leaks like oil lines.
    Could the oil pump check valves/balls allow all of the oil to drain out over time thru the engine cases?
    Thanks in advance,
    D.J. Knott
    AMCA #10930
  • Sargehere
    Member since 1972
    • Jul 2006
    • 971
    Yes, the check ball pressed on by the spring in your oil pump. Go by the Service Manual (do you have a service manual for 45s? Let me know.)
    With the tank empty, take the oil pump check valve apart (cap screw off, adj.screw out, spring out, fish out ball with a leetle magnet "on a stick" and clean it. Put it back together per the Service Manual.
    You now have a crankcase full of oil. Drain that, too, before starting it up again, or you may get oil all over.
    Gerry Lyons #607
    http://www.37ul.com/
    • Knotthed
      • Jul 2008
      • 195
      Sarge,
      Thanks for the response.
      I don't have a 45 "harley" manual per say - but here is what I do have.
      I have a 2" thick book titled 1940's military models WLA & XA operation maintenance specifications parts listings. I picked it up at a local flee market a year ago. I guess it is a "Harley" Book copywright 1985 after looking inside it just now.
      So you think it is most likely the check balls? That was my best guess, but I am very green with the old bikes and in the process of changing that.
      I cannot confirm that the engine is full of oil - where it is dripping on my floor suggest it is coming from the crankcase.
      This is for my Dad's 53 Servicar.
      Thanks again for your help!
      Donald J Knott
      D.J. Knott
      AMCA #10930
