Early 45 brake and clutch pedals,... Tech questions
  • 1776J
    • Jul 2009
    • 123
    So I'm in need of a correct brake and clutch pedal for my 1937 WL I'm working on, however, I'm coming up short finding one, and wanted to know if anyone reproduces them or better yet, anyone have originals they'd like to part with?
    Also, I'm looking for photos of them for reference.... if anyone has these early parts contact me, if anyone has photos of them on their bikes, etc. I'd appreciate a photo or two if possible
    Much thanks!!!
    "The beauty of life is more the crying baby than the great orchestra." -Woody Guthrie
  • Clydeflathead
    cantremember
    • May 2010
    • 51
    1937 45" clutch and brake levers
    Here are a few photos (not sure how well they look) of the 1937 45" clutch and brake levers. The brake lever is part #2956-35, it uses brake lever stud
    part # 2960-30, and brake lever spring part# 2964-35. The brake lever is marked with the numbers 326-371. The foot clutch lever is part # 2409-29 and uses clutch rod stud part # 2413-34. The clutch lever is the tricky one, as the part number stayed the same, but the lever changed sometime in 1934.The difference being the hole where the clutch rod stud goes thru. There
    is a hole for clutch rod stud 2413-29 for 29- early 34, it was changed a little in later 34 to accept clutch rod stud 2413-34 with a notch in the hole of the clutch lever. I do not know if you can see it clear enough (cheap camera) but
    I marked the flat spot in the clutch lever stud to show where it would fit in the notched hole of the later 34 clutch lever. Hope this is of some help.
    • Re-cycleInc
      • May 2009
      • 43
      I think I've got a clutch setup laying around. I'll check it out tonight and get you some pictures.
      Scott
      AMCA# 13993
