headbolt washers
  • 48hdbob1
    • Nov 2009
    • 111
    headbolt washers
    I have two types of headbolt washers for aluminum heads. Don't know which would be the right ones for '48 UL. thanks-Bob
  • Re-cycleInc
    • May 2009
    • 43
    Pretty sure it's the one in the first picture. Those are the only types that I've seen in the top end sets for my 45" models and I think they are the same for all flatheads.
    Scott
    AMCA# 13993
    • 48hdbob1
      • Nov 2009
      • 111
      I know the beveled type are the later type. They are a Harley-Davidson OEM part[NOS]. I just don't know exactly what year and if they were used in '48 on the U UL models. thanks-Bob
      • oldsouthmcy
        • Jan 2009
        • 51
        Actually, it's the other way around, beveled early/flat top late. Both carry the same part number, 15-39 (16822-39).
        The real problem is determining the date of change. I have a factory photo of a 1941 with head off and beveled washers. The washers that came off of a 1943 NOS motor were beveled. The washers on my 1951 & 1952 WLAs (originals) are flat.
        Unless you can verify otherwide with an original 1947 or 1948 Aluminum head equipped UL, I'd go with the flat top washers.
        Bruce Palmer III
        AMCA #667
        How to Restore Your Harley-Davidson
        How to Restore Your Military Harley-Davidson
        • 48hdbob1
          • Nov 2009
          • 111
          OK, thanks-Bob
