Intro and 45 springer question
  • Mikedt
    • Sep 2009
    • 5
    I am a long time member of the AMCA, but have only recently started to visit the forum pages. Over more years than I care to claim, I've been collecting 45 parts, but haven't completed much work.
    I'd like to start on some sub-assemblies and have a question about my springer. I have Bruce Palmer's Restoration book and understand that the 45 used several sub-types of the basic solo springer over the years. Would someone assist me in identifying which sub-type I have so I can use the correct spring rod ball, etc.?
  • flat-happy
    • May 2009
    • 543
    the balls are interchangeable. you just use the correct one for the year. 1931-1945 used the early ones with the contact ring around the outside and 46-57 used the smooth ones and the ball retainer plate
    • Re-cycleInc
      • May 2009
      • 43
      MikeDT,
      It looks like you've got a '47 and later leg. The spring fork perch was changed on '47 models which are discernable by the lack of the two inside grease fitting bosses used from '40-'46. Below is a picture of a '40-'46 fork leg that has the two unused, unmachined bosses on the inside of the perch. Hope that helps. I'm sure some other folks will give some more input as well.
      After looking at my own leg I've actually got some questions about my own fork but I'll wait to ask them until your questions are answered.
      Sorry the image got messed up, but you can get the idea on the grease bosses.
      Scott
      AMCA# 13993
      • Re-cycleInc
        • May 2009
        • 43
        Ok, how about another fork question....
        Does anybody have any idea why someone would braze the laminated plates above the fender tabs on this '40-'46 fork? It also has another reinforcement on the brake control mount. I'm guessing someone beefed it up for racing purposes?
        A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
        Scott
        AMCA# 13993
        • Mikedt
          • Sep 2009
          • 5
          Thanks Re-cycleInc. That's exactly what I was looking for. I read the description in Palmer's book regarding the unused pads, but without a photo I wasn't sure what they looked like.
