Question on valves/seats
  • Lincoln
    • Apr 2009
    • 12
    i'm rebuilding a '28 Single and wanted to determine if the valve seats were serviceable or not. The exhaust valve rests on its seat about a 1/16th of an inch above the seat face and the intake is about half that (see pics). Both valves are oversized. I still have to lap the valves which may sink them in a bit further. So my question is should the valves be flush with the face of the cylinder or should they protrude as they are now, and if so how much should they protrude.
    Many thanks!
  • hdrl1935
    • Jun 2009
    • 32
    I'd say you are fine. Now if the valves sat below the surface of the cylinder, you'd have some issues.
    • flat-happy
      • May 2009
      • 543
      it looks fine to me too----lapping them in won't lower them at all. at least it would be very hard to measure how much.
      • cubman
        • Apr 2009
        • 52
        valve guides
        Were you able to come up with valve guides or were you able to save the originals? Later Mike
