VL Tranny Pull
    • Aug 2001
    • 1343
    VL Tranny Pull
    Any secrets I need to know to pull tranny out of my '35 VL? Do I need any special tools? Clutch hub any problem to pull? Never removed it and going to jump on it tonight and just thought I'd ask the experts. Thanks.
    Louie
    YouTube >>> LouieMCman
    • 5954
    You don't need to take the clutch off to remove it. Just remove the motor sprocket and remove the clutch, parimary intact.
      • Aug 2001
      • 1343
      I believe third gear is my problem so might as well pull it all apart and inspect clutch plates.
      Louie
        Dear Louie, the gearbox X-tool 12017-X is handy in removing the lock ring nut and ball bearing holder on 1916-36 transmissions. The clutch removal tool 12022-30 is great at removing the clutch, as it pulls from the centre and does not risk distorting the clutch drum like a big puller on the outside. However, it's expensive enough that you need to remove a few clutches to get the benefit. A small puller is also handy for the starter gears, but the whole transmission can be stripped without special tools if needed.
          • Aug 2001
          • 1343
          Thanks all, I got it all apart, only had trouble with the clutch hub. Now the fun of rebuilding!
          Louie
