There's a 36VLH 80" Cylinder and Head on Ebay.
  • Sargehere
    Member since 1972
    • Jul 2006
    • 971
    I've posted this a couple of places, in case anyone is interested:
    Only trouble is, it's the front cylinder on an incomplete 1940 Harley-Davidson Flathead "U" motor. The seller apparently has no clue. He's included the bastard motor with a de-tabbed Panhead frame and some other stuff as a "project."
    The motor would never work, and would never work in that frame, with the front exhaust sticking out to the side and into the rt. front downtube anyway. There's a late model springer in the pile, too. Someone needing a VLH cylinder should buy it all and put it out of its misery. I'd be interested in the late springer.
    Harley-Davidson : Flathead, Ebay Item number: 170273890965
    Or this:
    http://tinyurl.com/6lxwmc
    __________________
    Gerry Lyons #607
    http://www.37ul.com/
  • Sargehere
    Member since 1972
    • Jul 2006
    • 971
    Never mind. It's probably a 7-bolt VL front cylinder stuck on the U lower end.
    Gerry Lyons #607
