56 Servi Car Oily & Smokey Mess!
  • ratfink
    • Aug 2005
    • 69
    If I let my 45 sit for over a week, when I go to start it, oil flows out of the overflow and it smokes like chimney. The motor is a fresh rebuild with 200 miles.
    I am assuming the oil is flowing past the check valve on flooding the lower end. Am I correct? If so, what is the fix? And why the excessive smoke?
    Thanks.
    \'77 Sportster
    \'68 FLH
    \'61 Super 10
    \'56 Servicar
    \'59 Hummer
    • 5950
    You are correct.
      • Jul 2003
      • 1832
      I had a 45 solo model that was famous for doing that. It put big oil puddles in my dad's driveway. Boy he hated that! I think it just took a new ball in the check valve to fix it; possibly also the spring....
      Herbert Wagner
      AMCA 4634
      • Glenn
        Member to Remember
        • May 2007
        • 403
        I have tapped mine with a drift punch to make a little better seat and it has worked
        moose
        Moose
        aka Glenn
