M88 Modification to use larger M51 venturi
  • #16
    It is not just the modern fuel that eats away at parts. Many states allow waste chemicals to be dumped into fuel mixtures. It is their way of getting rid of toxic waste chemicals. We pay for the personized dumping of them, via our convertor equiped machines. It is cheaper for us to burn it up than it is to bury it deep into mother earth. Don't believe this ? A little research will shock you. Paps
    • #17
      nice pics Cotton, I didn't know you had a guest appearance in "The Blob". I understand your reluctance to trying more sealants that may not work next year. So far I have had decent results using some of loctites products for sealing difficult things. Although I do try to avoid them if I can. The only modern slop I will admit to being almost addicted to is Hylomar.
      Brian Howard AMCA#5866
