VL springer fork rattle
  • VL springer fork rattle
    The buffer springs inside the the lower fork springs are rattling and driving me crazy. Am I missing some parts? Is there a quick fix?
    Thanks for your help.
    Tom Pribyl
    Tom, Do you have the flat springs installed inside the buffer springs? Two flat steel strips about four inches long with a bow in them that fit into milled area on spring rods. Later buffer springs are bent to stop rattle. VL are straight and need the anti-rattle spring. Robbie
      That must be it! I don't have the straps. Many Thanks. Tom
        Check your parts books
        Part number is 2623-23
        Flat check spring
          Got it....Thanks, Earl
