Screenshot_20261127_172739_Gallery.jpg Got some bad threads on the oil pump. Welded a double nut on the oil line and cut new threads all the way down the oil pump 9/16 by 24. Leaking bad. Any fix ideas? Doesn't have to look perfect for now. Thanks
Oil pump threads
The way I did it to later pumps, Dallen,
Was to mill off the original fitting to a flat surface, where its gallery could then be reamed reasonably round.
Then I took an old ordinary 63533-15 line fitting and turned down the hex and threads to where it would center in the hole with flush faces. Then I could silver-solder and dress it to look quite authentic (and it would not back out upon future disassembly of a frozen linenut).
The Colony repair item not only requires the same millwork, but tapping, if there is enough casting; Note straight threads will not seal.
....CottenLast edited by T. Cotten; Yesterday, 10:02 PM.AMCA #776
