VL wheel hub replacement kit advice
  • Wildcat
    • Jul 2023
    • 66
    I remember reading somewhere that someone manufactured a neat item that would replace the internal parts of the wheel hub as it included the bearings, seals, etc. in one assembled piece. All that had to be done was remove the old bearings, seals and put this new assembly in place and go. It seems like a great idea and I am interested. Where can I get these and does anyone have any experience on how easy it is to make the change. I rebuilt my hubs and they are already getting sloppy. Thank you
    • 2176
    Ray Bartomeli from New England makes them. I understand that no machining is required. They will tighten up any bearing play but of course won't help if your problem is worn splines.
    • Wildcat
      • Jul 2023
      • 66
      What actually is the spline that you are referring to
