I am preparing to install the carb. and intake manifold on my 1937 UL the seals have a bevel on one side. should the bevel be facing the manifold nut or the cylinder head. And any other suggestions for the install THANKS if you can help
Correct install for peak seals
It should not only face the nut, Idfly,Originally posted by ldfly112 View PostI am preparing to install the carb. and intake manifold on my 1937 UL the seals have a bevel on one side. should the bevel be facing the manifold nut or the cylinder head. And any other suggestions for the install THANKS if you can help
Their angles should match; Many (but not all) of the failed mass-produced seals that crossed my benches could be blamed upon funky aftermarket nuts, at least.
The flat face of the seal should butt up against the face of the nipple, which should be inspected and dressed as necessary.
The condition of the manifold spigots and a tight fit of the PEEK seals is critical, especially since mass-produced seals used the minimal outside diameter of stiff brass seals, instead of maximizing it for the compliant plastic.
....CottenLast edited by T. Cotten; 02-01-2026, 03:57 PM.AMCA #776
Tom, your experience and sharing of your expertise on this post and so many others is appreciated. Thank you.Bob Rice #6738
