oil pump parts
  • Jarek
    • Nov 2023
    • 306
    oil pump parts
    I have a leak here from oil pump. Any ideas? Or maybe there are some spare parts available?
    Dear Jarek, Harley used steel shafts running in the alloy bodies for these parts. Maybe try to find a less worn alloy cover or put in bushings.
    • Jarek
      • Nov 2023
      • 306
      Thanks, Steve, maybe in winter will take care of it.
      For now, I want to figure out what can be done.There is a thin wall for the bushings but I have to do something about it because the leak is quite big.
      • FNG1
        • Oct 2014
        • 201
        Just spit ballin here. If you are going to bore larger for a bushing. Maybe you could cut a chamfer or counter bore suitable for an "O" ring to fit under the lever.
