VL Oil Pump
  • Peter Cooke
    • Aug 2012
    • 570
    VL Oil Pump
    Would appreciate people's thoughts on using this oil pump or not? It came in the box of 'stuff' with my 31V and it appears someone has had a good time removing the old bronze bush with a small cold chisel, or something similar, and broken a piece out in the process. I've cleaned it up and got rid of the squarish corners and it doesn't appear to be cracked anywhere else.
    The ID measures within about 1 thou of being round so no problem there. I've almost convinced myself that it'll be ok to use given that it'll be sandwiched between a new bronze bush and the lock nut so shouldn't really present an issue but would appreciate any input in case I'm missing something.
