VL transmission cluster
  • cHarley32
    • Dec 2017
    • 11
    Trying to find the difference in stamps on transmission clusters for my VL. Have one stamped with a C and one with a V. Have not pulled the C out of transmission yet. Just trying to find out if anyone knows the difference. I do not see anything significant so far. Thank you in advance.
    There were two countershaft gears used on the VL, the early one through 1931 then the 1932-36 type with more bearing surface. I'm not aware of any meaning to the different stamped codes on a particular type.
    • cHarley32
      • Dec 2017
      • 11
      Thank you Steve for your response.
