Old magazins
  • Jarek
    • Nov 2023
    • 306
    Old magazins
    Hi, does anyone remember if there are any articles about the three-brush generator and the ignition coil in old magazines?
  • PaulCDF
    • Aug 2019
    • 1429
    Try:
    N1-11: Electrics Generators Part II (Spring 2011 pg 62)
    N4-10: Electrics Generators Part I (Winter 2010 pg 64)
    ALSO SEE In the Library
    Uncle Franks has information about generators.
    Hope this helps
    • Jarek
      • Nov 2023
      • 306
      Thank you PaulCDF , I found it.
      Here is probably the same ignition scheme as in HD
      1 - battery
      2 - ignition switch
      3 - ignition coil
      4 - ignition interrupter
      5 - spark plugs
      1722343037062.JPEG ​​​​​​​
