Linkert carburetor covers and atomizer
  • epazikas
    • Dec 2018
    • 104
    Dear colleagues, does anyone have the experience in using one of these small Linkert carburetor covers instead of the big air filter pan?
    is there a possibility to secure an effective protection by using these covers, like adding an atomizer beneath or perhaps making a mesh filter under the cover?
    Thanks for sharing. Ed
    This gallery has 1 photos.
    Dear Ed, the Harley carburetors did not have a mesh pack until the optional 1935 item, and most roads were still unpaved then. I would not worry about modifying your cool cover.
    • epazikas
      • Dec 2018
      • 104
      Hi Steve, thank you very much for your reply. It is great to hear you see no problem in replacing the pan type air cover by a smaller one. My concern was that in the big oil cover I normally apply oil on the mesh filter, while in the one I referred to in a picture, it wouldn’t be possible, unless I add to that an Atomizer (picture) net and somehow make a filter to it, but if it is not required, then the problem is solved.
        • 8244
        What does the backside look like, Ed?
        Some had clips for a sheet of mesh:
        Oil only works electrostatically with copper.
        PS: L&L offered custom horns...
        But they weren't the same as yours.
        • epazikas
          • Dec 2018
          • 104
          Hi Cotten, here is a picture of the back side, there is no clip on it.
          I thought to fit an atomizer behind, I’d it would be of any help or need,
            • 8244
            Looks boogered to me, Ed!
            And I suspect the atomizer was designed to extend into the carb, rather than the horn.
            The one on ebay looks like its ready to fall apart...
            • epazikas
              • Dec 2018
              • 104
              I agre, but I was thinking more about to fit the new carburetor cover on top of this other atomizer net, which is different from the one from eBay (see pictures).
                • 8244
                The best I can say about it, Ed,...
                Its not as restrictive, at least.
                It is silly to call either an "atomizer" when they are upstream of the fuel flow!
