Harley VL sealed wheel bearing trouble
  • montij
    • Jul 2022
    • 138
    I bought these sealed cartridges for my VL hubs from Vtwin after reading a few success stories and doing a bit of research. The bearing collar does not protrude from the hub when completely assembled thus not allowing the wheel to turn. I tried both units (one was black and the other was bare metal) and neither one is sticking past the nut when fully tightened. I don’t understand how this can be sold if it doesn’t work whatsoever, these were not cheap. I attached photos of both bearings in the hub sitting just below flush when completed when they should be proud at least 1/32 to enable the wheel to turn.
    Any advice would be appreciated I can’t return these.
    This gallery has 2 photos.
    Justin Monti
    AMCA #43973
  • tgarcia
    • Jan 2023
    • 116
    Can you make a little shim to get the protrusion you need?
    • montij
      • Jul 2022
      • 138
      I would have to. However I’m not a machinist and have no idea where I would get this made in my area. I have the 32 and later long spline hubs I wonder why more people are not reporting this issue.
      Justin Monti
      AMCA #43973
      • tgarcia
        • Jan 2023
        • 116
        Fair enough,if you give the inside diameter, outside diameter,and length you need ill spin you out a couple and send them to you if you want
        • montij
          • Jul 2022
          • 138
          I would appreciate that so much and gladly pay you for your time. I have some good measuring tools I’ll take a few measurements and message you.
          Thank you.
          This is what makes the AMCA great people who are willing to help each other.
          Justin Monti
          AMCA #43973
          • montij
            • Jul 2022
            • 138
            I took the measurements with a micrometer but realized at the end that I must somehow mill down the threaded cover by 1/16 to make this work. Adding a spacer will not help.
            This gallery has 1 photos.
            Justin Monti
            AMCA #43973
            • tgarcia
              • Jan 2023
              • 116
              Ok I think I see what you have going on there.the large threaded nut sets a preload and the spacer that's on it sets the wheel space correct? That would be easy enough to spin that much off the large nut if that's what you want to do. Would do that for you too if it will get you up and running.
              • montij
                • Jul 2022
                • 138
                Pretty much the bearing is a complete unit that drops in
                I had to modify my original hub to use these there is a large washer that must be pressed out. Yes I would need the nut machined down 1/16.
                Justin Monti
                AMCA #43973
                • montij
                  • Jul 2022
                  • 138
                  Even in Vtwins own instruction photo you can see the bearing sits below the cover. They are selling a product that doesn’t work . The second picture is how it should look. That is a bearing made by Ray bartomeli which I just discovered and will be ordering for next time.
                  Justin Monti
                  AMCA #43973
                  • Peter Cooke
                    • Aug 2012
                    • 570
                    What about using a washer, with a slightly smaller OD, in between the axle spacer and your bearing collar. Those parts don't turn anyway so that may work for you.
                      Don't forget to complain to V-Twin.
                      • tgarcia
                        • Jan 2023
                        • 116
                        Sent you a pm Justin
                        • knucklehead 61
                          • Sep 2016
                          • 350
                          typical v-twin (lack) of quality control.
                          I have installed these in 3 of my VL's.
                          the fix is simple, especially if you have a bare hub.
                          chuck the assembled hub in a lathe & turn down the locking end cap face deep & wide enough to allow the axle spacer to clear it.
                          the modification will be completely hidden by the axle spacer.
