Hello coleagues, I have recently serviced my motorcycle scavenger oil pump and I replaced its nipple, however after I assembled all together, I noticed a small leak (see pictures). The oil line is tightened well, but still a bit oil oil is dropping down. Any suggestions? Should I use perhaps some sealant? Thank you for helping me out.
Harley Davidson WLC scavenger oil line leak
Epazikas,
Do your best to verify that there are not any cracks in the pump casting, oil nipple, oil line nut and the taper area of the line itself.
If those items appear to be OK along with all other Gasketing, you can assume the fitting threads are wicking oil and the cause of your leak.
I can see signs of this in the one photo showing it assembled, I'm just not sure if it was all washed away clean after assembly. It's possible I'm seeing assembly oil residue in the image.
Regardless if things check out, use Loctite Thread sealant 565 in its correct intended way of application on that type of connection and your leak will go away.
Hope this helps,
DukeLast edited by dukekleman; 02-04-2024, 06:57 AM.
- 1 like
How was the replacement nipple installed, Ed?
If it was threaded into the casting, there would be the most likely leak.
I silver-soldered a couple easily, with no need for tapping threads at all.
....CottenAMCA #776
- 1 like
Originally posted by dukekleman View PostRegardless if things check out, use Loctite Thread sealant 565 in its correct intended way of application on that type of connection and your leak will go away.
Originally posted by T. Cotten View PostHow was the replacement nipple installed, Ed?
I am attaching a few pictures from before the work was done, I think the oil pump didn’t show any signs of damage, but feel free to comment.
What I did now was to apply a tin layer of Hylomar blue around the threads. I hope this is going to resolve the problem. I was told that Hylomar is recommended for these kind of applications because different than silicone, it doesn’t harden and it is not permanent, but I am not an expert.You do not have permission to view this gallery.
This gallery has 4 photos.
Hope this helps,
Duke
There are no cracks on the oil pump, so from that perspective I think we are good, but honestly speaking I would prefer to even consider to have a scavenger extra oil pump as spare, one never knows when it is needed and I only have the feed oil pump as extra.
i applied a hit of Hylomar yesterday before I read your comment, I hope it will work and that I did a good choice. In the worst case scenario I will undo the exhaust pipes and remove the oil pump again for a proper check, but I am optimist and hope this to not be necessary.
Since the flare nut threads are a much larger diameter than the threads into the casting, Ed,..
Any loosening of the flare nut will tend to back out the insert.
Thus I used silver-solder to not only seal, but secure the repair.
PS: No threads seal themselves, except tapered pipe threads, which are notorious for associated stress-cracks.
PPS: Hylomar never impressed me.Last edited by T. Cotten; 02-05-2024, 10:34 AM.AMCA #776
Originally posted by Peter Cooke View Post
Excellent, thank you. That's another option then.
How many existed when the machines became legendary icons?
How did they ever get along without them?
....CottenAMCA #776
EZ Turn worked on my VL oil lines/threaded nipple connections. No more oil dripping on the generator from the pump feed line that crosses in front of the engine.
- Loch
Excellent, thank you. That's another option then.Last edited by loch; 02-06-2024, 08:19 AM.
Everybody loves another goober, Peter!
