1929 Harley DL motor in later 3 bolt frame
  • Buster
    • 385
    What primary chain alignment problem will I have trying to use a 1929 DL motor in a later three bolt frame with later three bolt trans and clutch basket. Thanks.
    • 4789
    None, the primary side is unchanged for the chain line, the 7/16" offset is all on the rear drive side.
