rear brake shoe spring question 1935 VLD
  • Wildcat
    • Jul 2023
    • 66
    My rear brake has one new spring on the bottom that someone replaced and on the top side the old spring is broken.
    Is there anywhere that I can buy a spring like the one shown on my brake shoes as that will work for the top?
    I would think that this type of spring would be used in many other applications.
    I checked the local auto parts store and they don't have one like this.
    thank you.
  • dukekleman
    • Jul 2022
    • 595
    That spring looks to be incorrect. The spring in the photo appears to be a heavier gauge wire, most likely a spring for a jiffy stand. The correct springs are readily available from aftermarket motorcycle parts retailer's.
    • Wildcat
      • Jul 2023
      • 66
      I will give them a try.
      Do you know of one that may have them?
      Thank you very much.
      • Peter Cooke
        • Aug 2012
        • 569
        Here you go.
        Harley Davidson 41835-30, 1930-57 BT Mechanical Rear Brake Shoe Return Spring | The Good Old Motorcycle Parts Company
        • Wildcat
          • Jul 2023
          • 66
          Thank you
          Happy New Year
            • 2030
            Those are Eastern MFG made & OK,...stay away from Vtwin made
            • Wildcat
              • Jul 2023
              • 66
              Thank you for your help
