Any one have any experience mounting these? TIA!
WLA floor board extensions
Yes, I have them on my '40 knucklehead which has the half moon boards. I don't know if they were made for the earlier rectangular boards but would fit those to I would think. In '41 or maybe a little later they came out with the tubular type? They were intended as rear passenger footrests but I use them on my solo machine so I have more space to move my feet around.DrSprocket
Rich - can you post a photo? Just so I can recon how they might attached.
I do have the '42 half moon boards. I very interested the the right side. I've got a lot of cables and stuff right between the right floorboard and frame. TIA!
EDIT: Do these only work with the earlier rectangle boards? If so, I may have to peddle these off.Last edited by Oko; 11-23-2023, 06:45 PM.
No I have them on the half moon boards. I don't post photos sorry. They sit over the back part of the board and the strap goes under and the screws on each side. They may not fit on a 45 if that's what your trying to put them on.I had a 45 and there is a lot going on with the boards mounting to the straps running fore and aft.DrSprocket
I have a set of them from Replicant Metals on my 40 Big Twin with half moon boards as well. They fit fine. My biggest concern is the mounting screw location on the left board coming into contact with my primary cover. I have a feeling at some point my primary cover is going to have a scratch and dent issue. But I do like having them for my feet to rest on. I'm tall with big feet, so they really help me.
20231124_080057.jpgEric Olson
Membership #18488
Thanks Eric. As for rubbing on the primary, why not just cut some metal off for more clearance. Those look like repop, so nothing to lose there.
And Rich, you are correct. Too much in the way on my 45. Besides brake rods on the right side, I have engine guards that negate putting them on the front of the boards.
EDIT: I've not given up yet! Has anyone put on longer floorboard mounting bolts to get the floorboards out away from the frame?Last edited by Oko; 11-24-2023, 01:43 PM.
I have never seen those on a WLA. The WLA was a Solo machine.Be sure to visit;
Were there 2 different types of straps? I seem to remember the square footboard straps were a straight piece of metal, but the half-moon straps had the divot in them to clear the footboard cleat.
Update: Installed them by using the 3.25-inch longer bolts. No issues. Not much more flex on the pedal straps than before.
And I gained the clearance for the floorboard extensions. The extra 1" of space cleared all the brake rods and springs.
They are shiny new painted, but that won't last long. This should make riding it more comfortable.
By the way, for you purists, this is a civilianized 1942. With lots of repop parts. It's to be a rider.
This gallery has 4 photos.
