1931 Harley VL with positive ground?
  • Buster
    • 385
    I am helping a friend get the bugs out of a very original poorly running 6-volt 1931 VL. We found that due to a previous wiring error the bike is running with a positive ground. We have corrected to negative ground. Would this previous positive ground have ruined coil, generator, or any other electrical components? I assume it would ruin the generator relay, is this correct. Thanks!
  • tomfiii
    • Jun 2007
    • 314
    Would have to reflash generator and make sure coil is wired properly. Relay doesn't care if pos. or neg.
    • Buster
      • 385
      How do you know which post is positive or negative on coil?
      • Peter Cooke
        • Aug 2012
        • 570
        Isn't the one nearest the front the positive? Green wire from dash I think.
        • Peter Cooke
          • Aug 2012
          • 570
          There's a wiring diagram in the link below.
          https://forum.antiquemotorcycle.org/...-panel-rebuild
          • Buster
            • 385
            Thanks again!
