1937 springer front brake grease zert
  • ldfly112
    • Sep 2017
    • 146
    I am having a hard time greasing the zert on the front back plate not sure how much grease is needed in there also there is a fitting on the bottom what is this fittings purpose Thanks if you can help
    • 4789
    Not much grease is needed, and the fitting on the underside is essentially a drain for excess.
    • Lyle Manheimer
      • Mar 2008
      • 193
      I would think you remove the fitting and pump fresh grease into the zerk until fresh grease comes out of the removed fitting?
        • 2042
        Lyle,That bottom drain fitting is a tube,no need to remove it to grease & that would be way too much grease.
