'32 VL - Ground wire connected to, well, nothing
  • loch
    Motorcycle Junkie
    • Sep 2022
    • 224
    I pulled the right-side cover to inspect the electrical connection at the circuit breaker and found a ground wire flopping around when I removed the cover. I assume it's a ground because the only place any power should be coming to the circuit breaker is from the coil. At least that's my understanding. The wire is visible at the top right of the circuit breaker cover.
    Thanks!
    Loch
  • Jim
    • Sep 2001
    • 789
    It goes to the Timer cable clamp screw. See the bottom of the photoimage_35646.jpg
    Jim
    AMCA #6520
    • loch
      Motorcycle Junkie
      • Sep 2022
      • 224
      Wow! Thanks Jim. Where did you get that diagram?
      • Jim
        • Sep 2001
        • 789
        AT some point not too long ago, I downloaded/copied it from this AMCA forum... but for the life of me, I don't remember who posted it, which forum it was originally in or any of that. I do know what day it is today though!
        Jim
        AMCA #6520
