Originally posted by T. Cotten
View Post
Intake nipple sealer question
Originally posted by T. Cotten View PostDoes anyone have evidence that the MOCO used any sealer, Folks?
Thanks in advance,
....CottenThat's a great question, Gitguy!Originally posted by gitguy View Post
Did the MOCO use PEEK seals or bubble test each motor for intake leaks before it left the factory?
There is a mention of bubble-testing in the Panhead manual compilation, but I think it was for oil pumps (somewhere around page 300 or so..)
We can be pretty certain about PEEK though.
Back to topic:
I suspect Chief cylinder nipples were sealed with white lead.
....CottenLast edited by T. Cotten; 12-29-2022, 04:48 PM.AMCA #776
Tom, I've wondered if H-D used a sealant on intake nipples and would think they would just to cover manufacturing imperfections. I know on pocket valve Js they used a substance called 'plumbago' to seal the intake housing to the cylinder. I would think the white lead that plumbers used would both lubricate, and help seal a threaded nipple. If you could still buy white lead, I'd try it.Eric Smith
The reason I ask, Eric,..Originally posted by exeric View PostTom, I've wondered if H-D used a sealant on intake nipples and would think they would just to cover manufacturing imperfections. I know on pocket valve Js they used a substance called 'plumbago' to seal the intake housing to the cylinder. I would think the white lead that plumbers used would both lubricate, and help seal a threaded nipple. If you could still buy white lead, I'd try it.
Is because I have yet to find any evidence of any in the fossil record.
How'd they get away with it?
....CottenAMCA #776
Gentlemen, correct me if i am mistaken as to what plumbago is... if i recall correctly, in the 1918 Motorcycle Repairer, plumbago is described as an oil/graphite mixture. Would like to learn more about the mixture. i can only imagine lapping those inlet housings to the cylinder for a perfect seal was critical.Originally posted by exeric View PostTom, I've wondered if H-D used a sealant on intake nipples and would think they would just to cover manufacturing imperfections. I know on pocket valve Js they used a substance called 'plumbago' to seal the intake housing to the cylinder. I would think the white lead that plumbers used would both lubricate, and help seal a threaded nipple. If you could still buy white lead, I'd try it.Steve Swan
27JD 11090 Restored
27JD 13514 aka "Frank"
The only reason I mentioned this Tom, is that the technology has obviously improved over time and although using a "goober" to seal intake nipples might have been a fool's errand in the past, maybe using one of today's new and improved "goobers" might be an effective solution.Originally posted by T. Cotten View Post
Back to topic:
I had an intake leak on my 32 VL that was causing me fits. Finally at the recommendation of a friend I tried Hylomar blue sealant. I was reluctant but out of ideas. After that that the motor ran like a Swiss watch.
Your bubble testing advocacy has been one of the best tips I've run across. Thanks to you, I've made test plates for each of my bikes and having a no leak manifold makes a huge difference in how these machines run.
Thank you sir!
Hylomar®, Gitguy,..
Remains fluid. Think about it.
(My point, once again, is that if a mechanical seal is achieved, then you cannot credit the goober,... unless it finally fails.)
Any goober expected to resist the ever-changing fuels should be thoroughly tested before investing time, energy, gut lining, and money.
My immersion testing last decade showed next to no non-hardening sealers survive. (One that did was Permatex's The Right Stuff® (Grey), but it says right on the label its not for gasoline!)
Even hardening epoxies like J-BWeld® required weeks of cure before it was fully resistant.
....CottenLast edited by T. Cotten; 12-30-2022, 11:15 AM.AMCA #776
Steve, I believe there is also lead in that plumbago mixture, possibly a lead powder, or white lead mixed with the oil, and graphite. I found this somewhat amorphous definition on the internet:Originally posted by Steve Swan View Post
As nouns the difference between plumbago and lead
 is that plumbago is (mineralogy) graphite while lead is (uncountable) a heavy, pliable, inelastic metal element, having a bright, bluish color, but easily tarnished; both malleable and ductile, though with little tenacity it is easily fusible, forms alloys with other metals, and is an ingredient of solder and type metal atomic number 82, symbol pb (from latin plumbum ) or lead can be (uncountable) the act of leading or conducting; guidance; direction, course; as, to take the lead; to be under the lead of another.Eric Smith
Eric, thanks for that! Having lead in the mixture makes sense in that it melts and creates a seal...?Originally posted by exeric View Post
As nouns the difference betweenà plumbagoà andà lead
à is thatà plumbagoà is (mineralogy) graphite whileà leadà is (uncountable) a heavy, pliable, inelastic metal element, having a bright, bluish color, but easily tarnished; both malleable and ductile, though with little tenacity it is easily fusible, forms alloys with other metals, and is an ingredient of solder and type metal atomic number 82, symbol pb (from latinà plumbumà ) orà leadà can be (uncountable) the act of leading or conducting; guidance; direction, course; as, to take the lead; to be under the lead of another.Steve Swan
27JD 11090 Restored
Uh Oh, Steve,...Originally posted by Steve Swan View Post
The melting point of lead is ~620°F.
By that point, I would have expected the gas tanks to boil over.
PS: Lead is quite compliant at normal temperatures, and Indian used it for oil pump fittings.Last edited by T. Cotten; 12-30-2022, 09:32 PM.AMCA #776
Too funny, but not with tanks exploding! Thanks Tom, for the clarification! So, the idea using lead in plumbago was to provide a squish seal of sorts...?Originally posted by T. Cotten View Post
Uh Oh, Steve,...
PS: Lead is quite compliant at normal temperatures, and Indian used it for oil pump fittings.Steve Swan
27JD 11090 Restored
My first guess, Steve,..Originally posted by Steve Swan View Post
Is that it served the same purpose as copper does in sealers today, except more toxic, and probably better.
....CottenAMCA #776
It was never easy for me, Otis!Originally posted by otis71 View PostBack to leaky rivets- I’ve found that the rivet holes are usually wallowed out and fitting a new rivet after making them round again is necessary. Generally an easy fix unlike pesky nipple threads.
First, I had to anneal spike nails in coals to cool overnight.
Next, the hole had to be reamed clean, and then a rivet cut from scratch to a light press-fit, with a tapered head to seal itself upon the inner surface of the nipple.
If I didn't already have an internal cam-action anvil, I had to make one.
With the anvil securely pressing and holding the rivet into the nipple on the inside, with a sealer of choice for luck, I could then trim it to length on the outside.
Then, hoping I still had two free hands, I could upset the exposed rivet, barrelling out its shank within the nipple and casting with minimal strikes, hopefully to appear like the originals, instead of an over-peened repair.
Then another bubble-test, and if successful, some rust protection.
Add at least an hour if its still in the chassis!
