Just wondering... is it possible to replace the oil seal in the VL transmission from the outside without taking it all apart? I've never had the trans apart and it's been years since I had the top cover off. I'm not really sure of the year of the transmission. I'm not really interested in rebuilding with sealed bearings as I don't have any way of pressing them in or machine work.
VL transmission oil seal
Overhauling the VL three speed is not so much of a big deal, and you should have it in and out in a day. It has become routine to put a sealed bearing at the kicker side, and often at the drive side. You should not need a press or machining, just warm the gearbox case if necessary. A procedure is in my VL restoration book, available from Replicant Metals.
Originally posted by duffeycycles View PostIf you want it to not leak,send it to Rob at Retrocycle in NJ
Originally posted by sswaney View PostComplete disassemble is required to replace the "seals". Like the later 4 speed transmissions, the number one reason for oil leakage on the 3 speed big twin trans is over filling the transmission.
Originally posted by Steve Slocombe View PostOverhauling the VL three speed is not so much of a big deal, and you should have it in and out in a day. It has become routine to put a sealed bearing at the kicker side, and often at the drive side. You should not need a press or machining, just warm the gearbox case if necessary. A procedure is in my VL restoration book, available from Replicant Metals.
Jim
AMCA #6520
