solenoid problem
  • jug
    • Jul 2018
    • 112
    solenoid problem
    Does anyone have the Delco part number for 71469-65 solenoid. Are they all made in China like the one I got just over a year ago? Thanks in advance.
    • 8247
    Probably Jug!
    Please note that if you are indeed working upon a Flatty, the MOCO produced the electric start on Servis a year ahead of the BTs, as it appears by literature, anyway.
    So it is an assumption that the -65 or -65A would also apply.
    Have you an original to compare?
    .....Cotten
    PS: I gave many solenoids a second life by flipping the copper-clad contact washer, and cleaning the cap contacts of course.
      • 2044
      Most new solenoids are crap.I have best results with Standard Motor Products # MC-STS1...[J&P #363-474]
        • 8247
        I discovered the hard way, Folks,...
        Weak batteries eat solenoids, even OEM.
        • jug
          • Jul 2018
          • 112
          Maybe found the problem. Jumping would make it good for next day or two. Seemed like coil was weak. As Cotten says take apart. Looked good but touched coil ground wire and had to resolder it. It works now but time will tell. Found out this one was made in USA. Thanks for the good advice from you guys but dont stop now. Keep it going
            • 8247
            The solenoid coil is only as good as the battery, Jug!
            If the battery is weak, the contacts will arc and burn,.. again.
            • chuckthebeatertruck
              • Jun 2018
              • 697
              What he said ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
              even a slightly weak battery will eat a solenoid.
              and, you’d rather eat a solenoid than under feed current to a starter motor.
              cheap solenoids aren’t always the evil cheap batteries are.
                • 8247
                Cheap batteries worked for me, Chuck!
                I just never tried to get four riding seasons out of them.
                PS: That saved generators, too,.. even more than solenoids.
                • jug
                  • Jul 2018
                  • 112
                  If I need to buy one what brand seems to be a better choice?
