1937 UL exhaust clamp location
  • ldfly112
    • Sep 2017
    • 146
    I am fitting the exhaust on my 1937 UL and i cant figure out where the front clamp goes it has a small clamp and a medium clamp i assume that small clamp goes on the frame and the other goes around the front pipe but cant get them to line up to hook the 2 clamps together . thanks if you have any suggestions
  • Highlander
    • Feb 2006
    • 97
    You are correct in where they are mounted. The small clamp mounts below the sidecar loop. I believe some of the exhaust pipe OEM clamps have a slight twist where the bolt hole tabs are to help with alignment. The repro clamps do not.
    • ldfly112
      • Sep 2017
      • 146
      Thanks a bunch
