having difficulties with a '55 servi car. front cylinder is not firing. it has spark and compression but definatley only running on the rear jug. i have changed everything twice including the air pressure in the tires.......hahaha... i think i need professional help for both me and the bike
mechanic needed
it,s almost 80 psi compression and the spark appears strong. would i not hear a serious leak on the front cylinder. sometimes when i run a wire off the front plug and touch the head with it, it runs better. you would think this would ground it out. i do that to the rear cylinder and it does ground it out. i have replaced all the intake parts changed the carb with one i know is good, had the vavles and seats redone, new gaskets on the cylinders, replaced all electrical related items twice.i'm at wits end. does any one a good flat head mech. in the jersey area.
Switch the plug wires and see if the problem moves.
Where are you in Jersey?
You could contact me off list.
cffrey@mindspring.com
