VL front end
  • OWG
    • Apr 2017
    • 12
    VL front end
    Need to replace the worn out springs in my front end.
    Does anyone have a suggestion on how to compress them. Thanks
    • 4791
    Pipe clamp or ratchet strap. Both will work. Compress, remove retainer nuts, slowly release the tension.
    • OWG
      • Apr 2017
      • 12
      Sorry, I wasn't clear. They are removed, I meant compressing them for installation.
        • 4791
        Same procedure in reverse....
        • HDSmitty
          • Jul 2017
          • 282
          Good heavy zip ties works well also. Hope this helps.....Smitty
          • Carter32
            • Jan 2013
            • 19
            Check out www.Ridingvintage.com they have an article on building a 1933 HD VL springer front end which is pretty good. Under the tech section ...Catch
