Knucklehead gas tank
  • ldfly112
    • Sep 2017
    • 146
    I have found a 1939 knucklehead gas tank just wondering if it will work on my 1937 UL Thanks if you can help
    • 4791
    Yes, it will work, just won't be correct. Knuckle tanks will work on a UL but not the other way around due to clearance under the tanks. They also hold about 1/2 gallon less fuel. There will be lots of room above the heads.
      • 2025
      You might be able to trade for a SV tank.
      • ldfly112
        • Sep 2017
        • 146
        sounds like it will be a very noticeable difference. Not sure what i am going to do im not concerned about the bike being totally correct but i want it to look right Thanks for your help
        • larry
          • May 2009
          • 247
          The difference is in the part you don't see. I've wondered why the factory made two different styles when the OHV tanks would work on all Big Twins.
          • JoJo357
            • Feb 2016
            • 3313
            Originally posted by ldfly112 View Post
            sounds like it will be a very noticeable difference. Not sure what i am going to do i'm not concerned about the bike being totally correct but i want it to look right Thanks for your help
            Here are 2. 1939's, the outward difference is...'Harley' Noticeable 112. You'd only slightly notice them in a crotch position, like these photos~~Where's Waldo?
            *M.A.D.*
              • 4791
              If you run alloy heads it will take up a bit of the space. However Jojo's pics aren't great since one is a Knucklehead. Note the bottom shape of the knuckle tank and how straight it is all the way to the gas crossover line as opposed to the rounded belly of the UL tank. And the left tank has no depression at all, the clearance is for the spark plug on the right tank.
              • BNSONS
                • Mar 2007
                • 178
                Sell the knuckle tanks (they're worth more than the flathead tanks) turn around and buy the correct tanks you need.
                • JoJo357
                  • Feb 2016
                  • 3313
                  https://youtu.be/h_SK8hKpWzA
                  *M.A.D.*
                  HarleyDavidsonKnuck_1938.jpg​​​​​​​
                  • ldfly112
                    • Sep 2017
                    • 146
                    thanks for all the pictures and sugestions I am going to install the knucklehead tanks and see what they look like my next meet will be Oley if i need i will try and find a set of ul tanks. I will be holding on to the knuckle head tanks never know what the future can bring
                      • 4791
                      Here are a couple of actual pictures of Knuckle tanks on a UL with aluminum heads. Red tanks are knuckle, gray are SV. DCP_4771.JPGDCP_4774.JPGDCP_4772.JPGDCP_4773.JPG
                      • JoJo357
                        • Feb 2016
                        • 3313
                        #2 post.
                        You could have saved everyone valuable time Robbie, if You would have slapped & swapped those tanks after the #2nd post--haha.
                        Nice job!
                        *M.A.D.*
