Nylon Throttle Shaft Bushings
  • Peter Cooke
    • Aug 2012
    • 570
    Wondering if anyone has ever tried nylon bushes in a carb?
    Harley Linkert Carburetor Throttle Shaft Bushing Set *NYLON* - TJs Motorcycles (tjsmotorcycleparts.com)
    • 8236
    I've used teflon and PEEK, Peter!
    And brass where there originally was no bushing,
    But usually I stuck with Monel, unless it had to be a one-off repair.
    Nylon can get pretty gummy when it gets warm.
    • Peter Cooke
      • Aug 2012
      • 570
      Thanks Tom, I was wondering if heat might be an issue.
        • 8236
        Its been decades since I shopped for nylon, Peter,..
        But there's a harder black nylon that would probably be better than anything translucent.
        The problem with a soft plastic, like teflon, is that abrasives embed. Thus soft plastics require a very sharp, unusually long, and expensive reamer, and hope the shaft ain't fat.
        If the bushings are "pre-sized", there will be no meat for correcting any alignment issues (which are most common with 4-bolt flanges).
        You never know what you've got until you've mic'd the OD and plug-gauged the bore; One set of stainless bushings that a customer bought on fleabay in a kit were two thou over on the bore.
        • Peter Cooke
          • Aug 2012
          • 570
          Good info as always, thanks Tom.
