Seal Ring 25281-37
  • bamacec
    • Mar 2019
    • 5
    Seal Ring 25281-37
    What's the function of the spring loaded Seal Ring (25281-37) inside cam cover that buffers against the oil slinger on generator shaft? Mine is currently cracked and stuck on the pins. Probably from someone driving cam cover off through generator hole. How important is the Seal Ring?
    • 4789
    It is part of the crankcase breather system to separate oil and air in the cam chest and should be there. It is replaceable and available.
