1937 UL brake hub
  • ldfly112
    • Sep 2017
    • 146
    1937 UL brake hub
    was the original rear brake hub cast or pressed steel I am seeing some aftermarket with both options
    • 2025
    The flanges on the 35 to 1939 wheels hubs were cast steel. Staring in 1940 they used drop forged steel. Jerry
    • ldfly112
      • Sep 2017
      • 146
      Thanks ill look for a cast hub
        • 2025
        That is going to be spendy. They call them 'step hubs' and they can be hard to find. Jerry
        • ldfly112
          • Sep 2017
          • 146
          I am sorry i called the question wrong I meant was the rear brake DRUM cast or pressed metal. I have the correct step hubs thanks again if you can help
            • 4791
            The drum was stamped steel, not cast. Cast drums first appeared on the '58 models as a running change necessitated by the new hydraulic braking system.
            The front drum on a '37 is also stamped, not cast.
