VL coil mounting position
  • scooterscum61
    • Jan 2021
    • 46
    Is there a correct position for the coil mounting on the down tube, looking at examples I see some mounted high and some mounted low .
    There is some flexibility, particularly with the later mount without the backing plate. My coils usually end up with about half of them above the primary cover when viewed from the side.
    • scooterscum61
      • Jan 2021
      • 46
      Thanks , Steve I appreciate the Info .
