Non Starter
  • Architect
    replied
    Compression should be more like 80-90 psi on a 45, figure that out first. Good luck.
  • kitabel
    replied
    With that CCP you have no engine vacuum, the carburetor has almost no signal.
    Whatever is causing that is your problem.
  • Steve Slocombe
    replied
    That flywheel timing mark does not show TDC but where the points should just be opening on full advance. An easy mistake, which I've made before, is to set the timing at the large end of the timer cam rather than the small end. Quite often you can get the bike running on one cylinder, then waste a lot of time on looking at other assemblies in trying to correct it. I also agree with Jerry that 20 psi is way low compression, and oil in the cylinders should help.
  • Jerry Wieland
    replied
    20 psi is real low compression but maybe rings are stuck due to long term storage. I would squirt some ATF into the cylinders and maybe run the engine with an electric motor for awhile to see if it improves. Jerry
  • JSB55
    started a topic Non Starter
    Non Starter
    OK, Experts, here we go again ...
    54 ServiCar bought at reputable auction some years back. Seller turned out to live very close to me, seemed an honest guy, and swore the bike ran fine before he shipped it to the auction. He even gave me his contact info in case I had questions once I got it home.
    Finally at the point of wanting it on the road, and it is cranky. I drained the gas tank when I knew it was going to sit for a while, and just put one gallon of fresh gas (regular) in a few days ago. If I start to unscrew the fuel strainer cap, I get gas coming out, so it seems likely I'm getting fuel.
    Linkert Carb rebuilt by ITW, manifold installed with Peek seals and pressure/soapy water tested. New plugs (Champion D16, gapped .028) with a dab of Dielectric Grease where the wires connect. Timing checked x 3 using flywheel TDC mark, watching the front intake pushrod for max valve closure, and test light on the points lever. The mark on the timing cam is dead on aligned with the felt on the points lever, with the twist grip in the full advance (twisted back) position. Points gap is .020 with a tad of resistance, and .022 feeler won't slide in there. Valve timing and lifter gaps double checked, and are spot on. Lifters move freely, and it appears all valves are opening/closing normally. Spark plug wires newly seated in the OEM coil, and I have spark at both plugs.
    When kicking over, every third or fourth kick, I get kind of like a dull backfire sound, or maybe it's one cylinder firing once. I can see spark at the points, and at both plugs. I've tried advanced, retarded, and in between for the manual advance and nothing seems to change. Ditto with choke open, closed, and in between.
    Battery shows 6.4 volts, drops to 6.08 with ignition on, and 5.75 with the headlight also on. Load tester, however, drops it to more like 4.75 volts, although it goes right back to 6.4 when the load is shut off. Amps are 14 +/-.
    Compression test shows both cylinders about equal, but only around 20 PSI, when they should be more like 50+, but this engine has not run in ten years or thereabouts.
    If low compression is my problem, anything I can try so I can avoid an engine rebuild for a year or two? I thought about popping the heads off and installing new gaskets, in case they are dried out and leaking.
    Is the battery more likely my issue? From what I've read, it should start even with a marginal battery.
    Thanks in advance for any and all pointers on getting this thing running.
    P.S. last time I had a kicker only bike was 50 years ago *LOL*
    EDIT: Forgot to mention, Condenser checks out good, but I had a second one, so I've tried with both. Coil resistance is 1.5 - 2.0 between the Primary contacts, and 3.6 between the Secondaries. Hard to measure Primary to Secondary, except by holding one meter lead to the wire where it attaches to the spark plug, and the other lead to the Primary on the coil. Meter jumps around between about 7 Ohms to 15, with an occasional spike to 20+, probably because it's hard to get reliable contact on both poles and my grip moves a bit.
